For static (pre-defined height/location) pausing, you could try to use a post-processing script. For dynamic (hitting 'pause' on the printer at any given time) there is no way the slicer could know that up front, so the printer firmware has to handle that (Ultimaker's do this properly, others might not).
nallath 1,123
Nope. Ultimaker machines handle this behavior on the firmware level, so it's not something that we built into cura. Other machines might need it, but it's up to them to add it to Cura.
