Thanks for the suggestion. I've had a look at the layer one in the layer view in both 13.06.4 (with Fix horrible Type B enabled) and 13.04. In both case with Raft, Exterior Support and Skirt count 1.
Screen shots below. 13.04 still seems better for this model.
gr5 2,243
That's not good.
There is a "bug" in that model. It has a rectangular block inside part of the important part of the model. I think the rectangle is for support. Anyway you should go to the expert settings "fix horrible" settings and check "type b". This should make it slice closer to Cura 13.04.
