Do you have a photo of what you mean exactly? Thanks!
@SandervG can you please help us
Edited by 3VimaWe can always try
What firmware are you using? It can be that your jerk and acceleration settings are sub-optimal.
How tight are your belts? And at what temperature are you printing (print head & bed)?
Bed temperature 115
I would still recommend to see if newer firmware is available. Is your Ultimaker 3 connected to the network? If your Ultimaker spent some time at a reseller or in a warehouse, it is possible that a new firmware is released in the time it left our assembly factory, and ended up at your doorstep
280ºC seems on the high side of things, could you try to reduce it to 260ºC?
But your radius doesn't seem that bad, does it? I put a ruler over your photo, and they seem pretty straight to me.
I will get back to you with new photos. I will try it again with reduced acceleration to 2000 instead of 4000.
Thanks for your help
Nicolinux 288
which printer do you use? Do you use Cura? If yes, which print settings did you select?
