Kernel update and recovery
leoz
Posted · Kernel update and recovery
I tried to change the linux kernel in order to enable some feature for experimentation purposes. I ended up with a bricked machine (kernel panic and just a U-Boot shell working). is it possible to recover the machine to a working state? Also, what is the procedure to change the kernel?
