SteveCox3D 85
I'm the same as Didier, I have printed with this filament and used the recommended colorFabb settings without any real problems. My main issue was ensuring that the material didn't warp on the buildplate, so I had to make sure I had a good, even adhesive layer on the glass before printing with it.
An example of the parts that I printed with it are attached.
If you suspect it could be due to the oiliness of the material then make sure first that the knurled drive wheel in the feeder is clean and free from any clogging, and maybe also play with increasing the pressure of this wheel onto the filament using the adjuster screw on the feeder.
DidierKlein 729
Hi, i have tried it on a um2+. I used the recommended settings. I dont know them by heart but it should be around 220c also it needs lower fans like 25 to 50%
