Ultimaker 2 - need to run the feeder motor to run in reverse
Posted
· Ultimaker 2 - need to run the feeder motor to run in reverse
Yes you have lots of choices.
1) UM2+ firmware will work as that goes the other way. You will have to adjust steps/mm most likely.
2) You can install tinker marlin - which I love - and which lets you toggle all feeder directions and adjust steps/mm in the menu.
3) You can swap the two wires in either (but not both) twisted pair. You just use a pin and push down on the angled piece of metal that holds the pin in and slide the pin out, then rebend that tiny piece of metal so it will start working again, swap the 2 wires and re-insert.
You will probably need to change the steps/mm regardless. I don't know if the um2+ firmware supports that or not although there is an gcode to set steps/mm. Followed by M500 to save it so it still works after power cycle.
gr5 2,230
So it might be easiest to do #2 above.
Spaziofranco 0
I need to invert the wires of the feeder. Do you know if there's a video tutorial? I'm afraid to break the connector. Thanks!
