nozzle size(s) available?
montejw360
Posted · nozzle size(s) available?
I can't find any good info on the nozzle size(s) available for the Ultimaker. I can find the build envelope, speeds, etc. Also speeds with ? nozzle would be cool to know.
I guess to be more specific, how small of a nozzle is available? I'm not really concerned with fast prints, more so with smooth finishes on the parts.
Thanks,
Monte
    • 10 months later...
    I can't find any good info on the nozzle size(s) available for the Ultimaker. nozzle would be cool to know.
    As David said, the UM ships with a 0.4mm nozzle, which is capable of making the standard 0.4mm wide lines, and up to 0.6-0.8mm wide lines, if necessary.
