I can load Cura 3.2.1 just fine, it's only 3.3.1 that I have having a problem with, opengl drivers are installed
You could try to start the AppImage in a terminal to see if there are any error-messages.
Open a terminal and move to the folder where your AppImage resists, then type
./Cura-3.3.1.AppImage
Here's the output from trying to run it from the terminal
~ $ ./Cura-3.3.1.AppImage
QApplication: invalid style override passed, ignoring it.
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 72: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 80: saw unknown, expected number
qml: TableViewSelection: index out of range
Here's the output if I run 3.2.1 in a terminal except the app actually starts and runs
~ $ ./Cura-3.2.1.AppImage
o.k. these messages seems to be "normal" - get the same here (Linux Mint 18.3) but it runs as expected.
Only out of curiosity what Linux do you use?
Also have a look in your homefolder for the hidden folder .local/share/cura
there should be the files stderr.log and stdout.log and a folder 3.3 with a file cura.log inside.
Maybe in these files is a hint what's going wrong ...
Didn't realize that was there, according to the log it has something to do with my printer configuration or at least that is the way I read it.
If I rename the /local/share/cura directory and then tried to start 3.3.1 it will then start as brand new asking to add printer. I have a PowerSpec Duplicator i3 Plus which is a rebranded Wanhaeo Duplicator i3 Plus as popular as the Wanhaeo printers are I am surprised it's not listed.
Oh am using LinuxMint 18.3 64 bit
gr5 2,210
Works for me in ubuntu linux. You need opengl drivers for cura to work. Do you have those installed? I didn't have to install anything but maybe you do.
