Thanks very much!
I'm using a TronXY X1, right now my profile is saying I can't edit it.
I've tried lubricating the z screw, which made a slight improvement, but didn't fix the issue.
It seems possible it's underextrusion from watching the print, but I have no idea why it's so localised, or how to fix it.
DidierKlein 730
Hi and welcome,
What printer is it (you can add that to your profile).
As it's always on the same height it's most probably hardware related and not software (i mean not slicing issue).
Check the Z-Screw or maybe print a simple model (like a cube) to check if the problem occurs at the same height, analyse what is happening.
