Posted · Airwolf Axiom Dual Help Please!!
I have a couple Airwolf Axiom Dual printers and the Apex software that Airwolf has created, and is trying to force their customers to use is junk and that's the only software they will support now.
I really want to run our printers on this new Cura software. We have Simplify3D but the new Cura 3.3.1 offers many more customization options and new features that I'm wanting to use. So I'm ready to switch to Cura now but I can't get a start up gcode to work on my printer from Cura.
The problem is all of the old Cura profiles I had won't work with he new Cura. And the Simplify start code won't work with Cura either. So I'm stuck.
Any help would be greatly appreciated.
I can't even find the variables to call out in Cura for the Temperature of the extruders, bed, or any other features. Can someone please help with this as well?
Thanks in advance!!
    Well I finally got a portion of the normal starting script to work but it's not honoring most of it.
    It is not heating the first extruder as I have set. It Heat's the 2nd extruder in segments, first to it's resting temp. then to it's printing temp. Then Retracts filament and moves to Home. But then when it goes to to the auto leveling routine like it always does just fine, it crashes the nozzle into the bed and keeps pushing into it for some reason.
    The only thing I changed from my Simplify3D settings was the actual Heat Temperatures instead of their variables it was using before, and I changed T0 to T1 and T1 to T2 for the extruders because it looked like that's the numbering Cura was using.
    Please help if you can.
    Here's what I have for now...
    ;Axiom Dual Start Code
    M42 P6 S255 ;Turn lights on
    G21 ;Metric values
    G90 ;Absolute positioning
    M83 ;Set extruder to relative mode
    M140 S110 ;Preheat bed no wait
    M104 T1 S230 ;Heat primary no wait
    M104 T2 S225 ;Heat secondary no wait
    M117 Homing... ; Print message on LCD
    G28 X0 Y0 Z0 F300 ; Home all axes
    M117 Heating...; Print message on LCD Display
    M109 T1 S230 ;Wait for primary extruder to reach temperature
    M109 T2 S225 ;Wait for secondary extruder to reach temperature
    M117 Cleaning... ; Print message on LCD Display
    T1 ;Switch to primary nozzle
    G1 E-20 F150 ;Retract filament
    T2; Switch to secondary nozzle
    G1 E-20 F150 ; Retract filament
    G0 X20 Y226 Z0 F7000 ;Rapid transit to brushes
    G1 Z-2 F7000 ;Lower to brush level
    G1 X138 Y226 F2000 ;First pass across brushes
    G1 X40 Y230 F2000 ;Second pass back across brushes
    G1 X138 Y230 F2000 ;Third pass through brushes
    G1 X40 Y226 F2000 ;Fourth pass back through brushes
    G1 Z0 F5000 ;Raise above bed
    G28 X0 Y0 ;Home x and y
    M117 Auto-Level Probing...; Print message on LCD
    M204 S300 ;Set accel for probing
    M203 Z4 ;Set z max speed for probing
    G29 ;Airwolf Axiom Auto level routine
    M204 S3500 ;Set accel back to normal
    M203 Z20 ;Set z max back to limit
    G1 Z10 ;Raise nozzle up 10mm
    • 1 month later...
    Hey Weprint3D, are you still having this issue?  Hopefully you found a solution by now.  We use both the Axiom Dual and Axiom 20 (Dual) with Cura (currently 3.3.1) and it works very well.  I've put a lot of work into custom Axiom printer 'definitions' to get the software to act nice and it was worth it.  Maybe we can help each other out with Axiom printer issues.
    - Matt
    • 1 month later...
    This works
    Startup
    M42 P6 S255
    G21 ; metric values
    G90 ; absolute positioning
    M82 ; set extruder to absolute mode
    M107 ; start with the fan off
    G28 F200 ; home all
    ;M109 T0 S240.000000 ; heat first nozzle for auto leveling
    M109 T1 S240.000000 ; heat second nozzle for auto leveling
    T0 ; switch to first nozzle and retract filament
    G92 E0
    G1 E-20 F500
    ;T1 ; switch to second nozzle and retract filament
    ;G92 E0
    ;G1 E-20 F1200
    T0 ; switch back to first nozzle for auto leveling
    G1 Z0 F1200 ; raise bed to Z0
    G1 X12 Y229 F7000 ; position nozzles before brush
    G1 Z-2 F1200 ; lower nozzles to brush
    G1 X148 Y229 F1000 ; clean nozzles
    G1 X12 Y229 F1000
    G1 X148 Y229 F1000
    G1 X12 Y229 F1000
    G1 Z0 F1200 ; raise bed to Z0 to avoid contact
    G28 X0 Y0 ; home x and y
    M204 S300 ; set accel for probing
    M203 Z4 ; set z max speed for probing
    G29 ; autolevel
    M204 S3500 ; set accel back to normal
    M203 Z20 ; set z max back to limit
    G1 Z5 F200 ; raise nozzle up 5mm
    ;M104 T0 S0 ; cool first nozzle after leveling
    M104 T1 S0 ; cool second nozzle after leveling
    ;T1 ; extrude filament back into second nozzle
    ;G92 E0
    ;G1 E20 F100
    ;G92 E0
    T0 ; extrude filament back into first nozzle
    G92 E0
    G1 E20 F100
    G92 E0
    M400 ; clear buffer
    G4 S1 ; pause
    G1 X20 Y200 F6000
    G1 F{travel_speed}
    M117 AXIOM Printing... ;Put printing message on LCD screen
    End:
    M42 P6 S255
    G21 ; metric values
    G28 F200 ; home all
    G92 E0
    G1 E-20 F500
    ;G92 E0
    ;G1 E-20 F1200
    G1 X12 Y229 F1000
    G1 X148 Y229 F1000
    G1 X12 Y229 F1000
    G29 ; autolevel
    ;G92 E0
    ;G1 E20 F100
    ;G92 E0
    G92 E0
    G1 E20 F100
    G92 E0
    M400 ; clear buffer
    G4 S1 ; pause
    G1 X20 Y200 F6000
    G1 F{travel_speed}
    Hey FORGEmfg, your startup code looks like it was straight out of APEX (for a primary-nozzle print) but your end code is actually just the start code over again.  You may not want to start the process over again when a print finishes.  According to the Cura definitions, the variable, "travel_speed", is no londer used.  You may need to use something else like "speed_travel" (mm/s) or use a value.
    Ok cool.
    Sorry, I messed up the control / paste.
    End code
    M400
    M104 T0 S0 ; switch off first nozzle
    M104 T1 S0 ; switch off second nozzle
    M140 S0 ; heated bed heater off
    M107 ; fans off
    T0
    G92 E0 ; set first extruder to 0
    G1 E-3 F300 ; retract a bit to relieve pressure
    T1
    G92 E0 ; set second extruder to 0
    T0 ; switch back to extruder 1
    G1 Z245 F1000 ; move to cooling positioning
    G28 X0 Y0 F8000 ; move to cooling positioning
    M84 ; steppers off
    Here's the startup from the Dual.  We have both (single and Dual) but I'm pretty sure I pasted the one from the dual.  Also updated last line per Matt
    M42 P6 S255
    G21 ; metric values
    G28 F200 ; home all
    G92 E0
    G1 E-20 F500
    ;G92 E0
    ;G1 E-20 F1200
    G1 X12 Y229 F1000
    G1 X148 Y229 F1000
    G1 X12 Y229 F1000
    G29 ; autolevel
    ;G92 E0
    ;G1 E20 F100
    ;G92 E0
    G92 E0
    G1 E20 F100
    G92 E0
    M400 ; clear buffer
    G4 S1 ; pause
    G1 X20 Y200 F6000
    G1 F{speed_travel}
    Quote
    Hi, Do anyone have the Axiom Dual Direct G Codes for Cura 3.6 ??
    Work for Dual extruders..
    My company bought an Axiom 20 DD and it's been a pain to print anything. I hate APEX and I'm working with Cura 3.6.0. Things I've done so far: created an Axiom 20 Machine profile and put in the start and end gcode pulled right of APEX. It runs through the bed level calibration just fine and ends good as well. 1st print was a temperature tower that looks pretty bad.
    Does anyone have a good profile for Cura that puts out good results. I need one for ABS and PLA.
    My only advice is to do as we did and sell that Airwolf Piece of junk and buy a Raise3d Pro2 printer. We did and it was the best thing ever. Amazing quality no matter what material. No more issues at all and great software! Airwolf is horrible, their customer service is horrible, their software is pathetic!
    Can't you just load the apex software and put the settings into cura?
    @Weprint3d I'd love to sell this thing but since my company paid an arm and a leg for the thing they are kinda hell bent on me getting it to work.
    @FORGEmfg I didn't even know that was an option but I'm not even sure i trust their setup values. Everything I've printed has been sub par and I wanted to see someones settings that were giving them good results.
    I have a Creality Ender 3 at home and I'm pumping out tons of cool stuff. The AXIOM is junk that I'm trying to salvage for my company.
    Best of luck my friend! The Axiom is total junk.
    Is very sad that peeps have wasted so much money and time on them including myself!
    My very first 3D printer was an AXIOM.  Paid $4K (50% up front deposit) and waited 5 weeks for it.  It died within the first 5 days.  Complete power failure.  Returned it to their facility in southern California (I also live in SoCal. Part of the reason I chose it in the first place)  They said it would be two weeks to repair it!!  I demanded my money back on the spot.  Got the refund because I charged it to my AMEX card and AMEX jumped in for me.  Purchased my first Ultimaker 2 Ext about a week later and a second UM2 Ext about a month after that.  Sold them both and now have two UM3 Ext machines.  Never regretted the purchase of my Ultimaker machines.  They are not perfect, but the combination of hardware and software supported by the same source, along with the excellent support from the folks at FBRC8, made sense to me.
    Good luck with the task your employer has placed before you . . .
    Hey folks. I've got an Axiom dual, and used to have this problem, this thread is still the top search result so I figured I'd pitch in to help others out. I'm running decently well on this printer now.
    Airwolf listed a start and end code set for alternate slicers, but it's still got a couple problems. Most critical are that the temps used for auto-leveling are fixed values at 240, and Cura adds extruder temps before the Start Code. So the start code needs to be modified with material temp variables per extruder, and I prefer them to cool to the standby temp, not to 0 after auto-leveling. I also don't have my extruder fan settings figured out yet, it isn't operating correctly with their base code. I've read that airwolf needed the fan to be at 100% or not at all, and read in another place that it'll work variably as long as it was at 100% from the start. For now, I left the M107 in, just as airwolf has in their recommended start code. Including the line M106 P0 did not turn on my extruder1 fan, so I have some figuring out to do still. I'll come back and reply if I figure it out.
    Next, keep in mind that if you deactivate extruder 2 in cura to only print with a single extruder, that you should change the cooling lines:
    M104 T0 S{material_standby_temperature, 0} ; cool first nozzle after leveling
    M104 T1 S{material_standby_temperature, 1} ; cool second nozzle after leveling
    to
    ;M104 T0 S{material_standby_temperature, 0} ; cool first nozzle after leveling
    otherwise it will try to print at the standby temp until the next temp change.
    Another way to handle this is just to duplicate your printer and have a different start code for the single extruder setup. Your call.
    Good luck!
    START CODE:
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    M42 P6 S255
    G21 ; metric values
    G28 F200 ; home all
    M109 T0 S{material_print_temperature, 0} ; heat first nozzle for auto leveling
    M109 T1 S{material_print_temperature, 1} ; heat second nozzle for auto leveling
    G1 F100
    G92 E0
    G1 E-20 F100
    G92 E0
    G1 E-20 F100
    G1 X12 Y229 F1000
    G1 X148 Y229 F1000
    G1 X12 Y229 F1000
    G29 ; autolevel
    M204 S2500 ; set accel back to normal
    G92 E0
    G1 E20 F100
    G92 E0
    G92 E0
    G1 E20 F100
    G92 E0
    M400 ; clear buffer
    G4 S1 ; pause
    G1 X20 Y200 F6000
    G1 F{travel_speed}
    M117 BOOM
    END CODE:
    M400
    M107 ; fans off
    T0
    T1
    G28 ; home all
    M84 ; steppers off
    M42 P6 S0 ; lights off
    Can confirm that the Airwolf Axiom runs all fans on the single M106 command. Do not set separate fan values for extruders 1 and 2 (P0 and P1 not used). It is also true that this printer (possibly a limit of Rambo v1.3??) only uses fan values of on or off. Anything less than 100% and it doesn't run. So set both regular and max fan speeds to 255 (100%).
    In my case, my extruder 1 fan was just wearing out. I found that if I flicked it, it would start up and get rolling from then on.
    Cheers!
    Hello everyone,
    Its been a couple years since the last post but my company bought this Axiom 20 duel back in 2017 or so and has been sitting for years till last month. I'm currently working on getting this thing running good. So far i found the running at 35mm/s travel leaves no ghosting (crazy how overpriced this printer still is 7 years later).  I got rid of the brass nozzle wipe (stupid and ruins your nozzles) and took it out of the start up g-code in Cura and just added a purge line instead. but now I need the distance of the second nozzle so that way I can add/use it so I can do a purge line for the second nozzle as well. any help will be greatly appreciated. I have a good Cura profile as well
    Hello, im fairly new to 3D printing and not familiar with AirWolf Axiom printers, but at work we have a printer no one uses and i would like to learn how to use it, im pretty sure it is the Axiom Single Extruder w/ Direct Drive.
    Ive tried to copy and paste a couple different start and end g code strings but after trying each one not sure where i am going wrong, any help would be appreciated
    ill post my gcode here
    Start
    M42 P6 S255 ; turn lights on
    G21 ; metric values
    M109 T1 S240.000000 ; heat second nozzle for auto leveling (in case machine selected incorrectly)
    G1 F100
    G92 E0 ; set extruder position to 0
    G1 E-20 F100
    G28 F200 ; home all
    G1 Z0 F1200
    G1 X20 Y228 F7000
    G1 Z-2 F1200 ; lower to brush
    G1 X138 Y226 F2000
    G1 X40 Y228 F2000
    G1 X138 Y226 F2000
    G1 E-30 F125
    G1 X40 Y228 F2000 ;
    G1 Z0 F1200
    G28 X0 Y0
    G29
    G1 Z5 ; raise nozzle up 5mm
    M104 T1 S0 ; cool second nozzle after leveling (in case machine selected incorrectly)
    G1 F100
    G1 E6 F100 ; extrude filament back into nozzle and 7mm more
    G92 E0 ; zero extruder
    M400 ; clear buffer
    G4 S1 ; pause
    M117 AXIOM Printing... ;Put printing message on LCDE screen
    End
    M400
    M107 ; fans off
    T0
    G28
    M84 ; steppers off
    ;{cool_code}
