Posted · Cura settings for Prusa i3
Looking for settings for Prusa i3. Not sure how to set it as I saw some topic that GCode has to be changed...
Maybe someone is using Prusa i3 with Cura...
Thanks in advance.
    • 3 weeks later...
    • 1 month later...
    I've been using successfully Cura for my Prusa i3 8'' with magma hot end (i can use ABS only with the hot end right now)
    Here are my settings:
    Dump it into any .ini file and load it with cura (V13.06.4)
    [profile]
    layer_height = 0.2
    wall_thickness = 1
    retraction_enable = True
    solid_layer_thickness = 0.9
    fill_density = 20
    nozzle_size = 0.4
    print_speed = 70
    print_temperature = 225
    print_temperature2 = 0
    print_temperature3 = 0
    print_temperature4 = 0
    print_bed_temperature = 90
    support = None
    platform_adhesion = Brim
    support_dual_extrusion = False
    filament_diameter = 2.85
    filament_diameter2 = 0
    filament_diameter3 = 0
    filament_diameter4 = 0
    filament_flow = 100
    retraction_speed = 30
    retraction_amount = 4.5
    retraction_dual_amount = 16.5
    bottom_thickness = 0.3
    object_sink = 0.0
    overlap_dual = 0.2
    travel_speed = 150
    bottom_layer_speed = 20
    infill_speed = 100
    cool_min_layer_time = 5
    fan_enabled = True
    skirt_line_count = 1
    skirt_gap = 3.0
    fan_layer = 1
    fan_speed = 100
    fan_speed_max = 100
    cool_min_feedrate = 10
    cool_head_lift = False
    solid_top = True
    solid_bottom = True
    fill_overlap = 15
    support_rate = 75
    brim_line_count = 15
    raft_margin = 5
    raft_line_spacing = 1.0
    raft_base_thickness = 0.3
    raft_base_linewidth = 0.7
    raft_interface_thickness = 0.2
    raft_interface_linewidth = 0.2
    fix_horrible_union_all_type_a = False
    fix_horrible_union_all_type_b = False
    fix_horrible_use_open_bits = False
    fix_horrible_extensive_stitching = False
    plugin_config = (lp1
    object_center_x = -1
    object_center_y = -1
    [alterations]
    start.gcode = ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    G21 ;metric values
    G90 ;absolute positioning
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G1 F{travel_speed}
    M117 Printing...
    end.gcode = ;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    start2.gcode = ;Sliced at: {day} {date} {time}
    G21 ;metric values
    T1
    G1 F200 E10 ;extrude 10mm of feed stock
    G1 F200 E-{retraction_dual_amount}
    T0
    G1 F{travel_speed}
    M117 Printing...
    end2.gcode = ;End GCode
    M104 T0 S0 ;extruder heater off
    M104 T1 S0 ;extruder heater off
    M84 ;steppers off
    support_start.gcode =
    support_end.gcode =
    cool_start.gcode =
    cool_end.gcode =
    replace.csv =
    nextobject.gcode = ;Move to next object on the platform. clear_z is the minimal z height we need to make sure we do not hit any objects.
    G92 E0
    G1 Z+0.5 E-5 F{travel_speed} ;move Z up a bit and retract filament even more
    G1 Z{clear_z} F{max_z_speed}
    G92 E0
    G1 X{object_center_x} Y{object_center_y} F{travel_speed}
    G1 F200 E6
    G92 E0
    switchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    G92 E0
    G1 E-36 F5000
    G92 E0
    T{extruder}
    G1 X{new_x} Y{new_y} Z{new_z} F{travel_speed}
    G1 E36 F5000
    G92 E0
