Posted
· Cura Connect stuck showing old print jobs
In about a month we expect to release firmware v5.2, a major release for the UM3 which integrates the S5. In this release over 150 issues in Cura Connect only were addressed, many feature improvements, but also bug fixes. When I checked the list there are several fixes related to (old) print jobs. Since we didn't experience the above mentioned problem in the system tests it seems likely the problem as described here is fixed.
Marco_TvM 34
This can be fixed by resetting Cura Connect on the UM3. Got to the menu System -> Maintenance -> Cura Connect reset (the one below Firmware reset).
This should fix your problem.
klaus_kraemer 3
This happens way too often to be solved with a workaround only!
CarloK 204
