Cura leaves weird holes in walls
ecake
Posted (edited) · Cura leaves weird holes in walls
Has anyone experienced Cura leaving odd holes in walls? It seems to be doing it with all models, not just ones I've made. I'm afraid to try printing it, to avoid wasting plastic. Cura is version 3.3.1
Edited by ecake
duplicate image? dunno how this works
    Posted · Cura leaves weird holes in walls
    You have coasting enabled:
    Without coasting it looks like this:
    The dialog you pictured above is controlling the setting visibility, not the setting itself.
    Strange. I guess the default profile has it on despite turning it off in the configuration. Thank you for the help. I really appreciate it.
    Oh. I see now. I didn't realize that's what it was.
    You're welcome, happy printing!
