Yeaah, i had 0.4 on bottom and top layer. I had removed the "bottom" layer from expert settings and i got this:
So what you say, 0.4 should actually be more like 2mm thickness.. since i do 0.2layer height that is around 10 layers extra? But how can it make it "smooth" and level when there are things falling?
Also after tightning the spring to 11.5 the plastic wheel inside pressing on the PLA is making a "unoiled door hinge sound". Is that normal? Sounds like it's gonna break the thing..
Edit: Fan is at 100% from layer 2 and up anyways
EDIT 2: The spring was tighten to 10.5 instead.. 11.5 silent <3 little squeeking but not so irritating.
illuminarti 18
Are you talking about printing solid layers over infill... e.g., the top of a cube? That's going to work better if you print slower, and make sure your fan is on. It does take several layers to fill it in smoothly. So set the top thickness to be 6 to 10 times your layer height.
(See: http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/?p=17300 for an example of the effect of cooling on top surface quality)
