Hi, i thought it was enought put printers type in the topic. I‘m sorry!
ultimaker 2+
Filament: pet (innofill), petg (two different brands)
I think it is not depending on filament because i print this filaments without this issue in former times.
At least one role was new shopped.
I forgot to tell, that increasing speed shows the same result...
and if i set the fan on, i cannot compansate the missing extrusion by increasing the extrusion multiplier...
i tried values more than 140% multiplier and temps over 10 degree over the specs.. it didn’t help.
the printig speed i can use is very less 60mm/s.
but please keep in mind:
the tempsensor vealue shows good match with low variations. Temp “seems” to be fine...
kmanstudios 1,117
Printer? Filament type? Etc.
