You shouldn't have to do a hot/cold pull every time you print with PVA. I print with PVA quite often, but sometimes I won't use it for a week or two and replace the BB core with an AA for whatever reason, and when I put the BB core back in, it usually prints PVA without troubles. I don't think I've done a hot/cold pull on the BB core for a month or two now, and the last print I did in PVA this week came out perfectly, and I hadn't used PVA or the BB core for a couple weeks now.
When I put it in and put the PVA, I let the printer do the purge when the PVA is loaded, the first few centimeters are leftovers from before that come out all bad and cracked and sizzling and slightly burnt, then the 'new' PVA from the spool comes out, all clear and nice, and that's it.
Do you have a drybox for storing the PVA when you're not printing? It's very important that PVA is stored in a low-humidity environment when not printing, because that's when it can absorb a lot of moisture. And the tiny packet of dessicant isn't enough once the PVA is out of the sealed plastic packaging.
Also, I'd try and check the BB core as well, if you have clogs that often. Maybe try with another BB core if you have one handy, just to see if you have the same problems. It's possible the Bb core is faulty or damaged.
Brulti 176
The only way to do that, as far as I know, is to perform hot and cold pulls on a regular basis to remove all the gunk and burnt particles inside the printcore that could be responsible for clogs and such. And, of course, when not printing, do not leave the filament inside.
I believe that the printer does some retraction when a nozzle is not used for printing, like, when nozzle 1 is printing and nozzle 2 sits idle, but I may be wrong.
Basically, regular maintenance, check-up and cleaning of the printer.
Also, proper storage of your PVA to avoid it going bad. This thing is a absorb ambient humidity like a sponge, and can turn bad very quickly. So, it must be kept in a closed box with some sort of dehumidifier that keeps humidity level below 55%. Else the filament will absorb ambient moisture and that can lead to bad prints and clogging, as it becomes mushy then all the humidity it absorbed is release when it is heated up for print, creating bubble and such. If you hear some sort of sizzling and crackling sound when PVA is extruded, it means it has gotten too much humidity in it.
Kathryn 0
Yeah that does seem to be the most effective solution- I was hoping to avoid having to do a hot/cold pull every time I start using the PVA again, but it's such a finicky material that may just be what it takes.
Good news is we do already have a small dry box that the filament sits in during printing, and it is true that that has helped substantially with avoiding clogs in the middle of a print.
