Fan problem
Pilotltd
Posted · Fan problem
Printer has two fans, fan0 is hot end fan and has temperature control set and comes on at 45C. Fan1 is print cooling fan. Printing ABS I only want hot end fan on. Untick cooling and it sends M107 which turns off fan0. Is there any way in cura to define fan numbers? Tried on both Cura 3.3.1 and 3.4 beta.
    Maybe a bug, but post processing plugin does absolutely nothing in 3.3.1 or 3.4Beta. Possibly because my install is 64bit, if the plugings are not compatible they wont work. Several other plugins don't work either.
    https://reprap.org/wiki/G-code#M106:_Fan_On
    M106: Fan On
    Parameters
    Pnnn Fan number (optional, defaults to 0)2
    Snnn Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))
    Extra Parameters
    Innn Invert signal, or disable fan1
    Fnnn Set fan PWM frequency, in Hz1
    Lnnn Set minimum fan speed (0 to 255 or 0.0 to 1.0)1
    Bnnn Blip time - fan will be run at full PWM for this number of seconds when started from standstill1
    I submitted PRs to allow the cooling fan number to be specified on a per-printer basis.
    https://github.com/Ultimaker/Cura/pull/3950
    https://github.com/Ultimaker/CuraEngine/pull/797
    Don't get too excited, these are unlikely to be incorporated for months (assuming they get accepted, that is).
    • Like 2
    • Thanks 1
