Does Cura add different start up scripts over usb? I’ll change the gcode flavor to marlin.
Obviously there is a difference, but why choose marlin gcode over Ultimaker 2 in Cura?
Also, as an aside when I print from simply3d on sd and start a print it says it’s going to override settings and to select continue it cancel. When I select continue the screen moves over to cancel but still prints as usual.
When printing from sd from Cura no such question is asked from the printer.
tinkergnome 918
Hi Nicholas,
i can imagine three possible reasons:
Can you rule out these possibilities?
