Trouble installing Cura 3.3
Posted · Trouble installing Cura 3.3
Hello,
For whatever reason I can get older versions of Cura (2.5 I think) to run on my laptop, but not any of the newer versions.  I always get this message when i try to run it after downloading and installing.  I tried redownloading it, uninstalling and reinstalling, but no cigar.  I also tried with 3.2 and the 3.4 beta with the same issue.  I'm running a fully updated version of windows 7 right now.  If anyone else had this problem or has any ideas on how to fix this I'd appreciate it a lot.  Thank you!
    I attempted a download from your link for the 64 bit windows 7 version and got a message instead saying "This update is not applicable to your computer", despite it being for the correct OS and bit version.
    It may be because it took me to what appeared to be an update page and I literally just updated before posting this question?  That was one of the first recommendations I got when I tried to research this issue.
    Okay just found out I don't have SP1 installed.  Doing that right now.
    Got it figured out after SP1 was installed.  Thanks for the links.
    Hello,
        When I open the installation pack, it always says "Error launching installer", can you pls help me solve this, asap!
    Many thanks!
