Extruder doesn't go low enough at the start of the print!
nagoL2015
Posted · Extruder doesn't go low enough at the start of the print!
As the title says. How would I do this? The default gcode file that came with it prints perfectly fine. But any print I try starts too high.
    Posted (edited) · Extruder doesn't go low enough at the start of the print!
    It would be nice if you give the 2 gcode files, the default one and one you sliced with Cura, just to see what Z coordinate are set in both files at the beginning
    Your printer has an auto leveling at the beginning, did you correctly check it in the case you're slicing with cura?
    Edited by JCD
    edit text
