tinkergnome 918
On 7/9/2018 at 6:59 PM, JohnInOttawa said:I've avoided ABS up till now and would prefer to stay away from it if I can. Will ASA do what I need for the outdoor piece? IF so, what experiences have folks had with ApolloX?
PETG wise, how has it gone with HDGlass?
I'm not sure if i'm doing something wrong, but i tried HDGlass and all parts come out quite brittle. In addition: I don't like the 'look and feel' and finally gave up with it. Instead i use either Ultimaker CPE or colorfabb nGen nowadays.
ApolloX is relatively easy to print (compared to ABS) and looks very nice. I printed some simple brackets in dark grey that are outdoors for approx. a year now. There's no visible discoloration or degradation. I'm not sure, if it is more 'healthy' to print, but IMHO it fulfills the promises as an UV stable alternative to ABS (it's only my gut feeling of course).
P3D 46
Hi, just one thing - Nylon has to be *printed* dry (otherwise there will be steam bubbles and material degradation), but once the object is finished, absorbed water tends to actually improve the material properties, especially toughness.
I have no experience with the other materials you mentioned, but PETG should be worth a try too, as well as ASA - maybe you can get samples or something, so you don't have to order a full spool.
