I didn't swap print cores.
It was working as usual and then, suddenly, all the bed leveling attempts goes wrong (try bed leveling, echec, retry... and so one until I discoverd that my print was still not finished)
No blob or filament and it's still printing with manual level.
The space before it stops is not just few milimeters, but almost 1cm... much more than what can be compensated with manual adjustments.
SandervG 1,522
Hi @SmartBlug , did you swap print cores or did you do something else prior to the bed leveling stopping to work?
If there is a little blob of filament on the tip of your nozzle it will give you such a similar message, so it is important to have a clean nozzle when you want to level your bed.
If something caused your bed to just be really off, the offset may be too large to be compensated by the active leveling. You could also do a manual level first, so it is at least almost level.
