Can't calibrate steps per mm... 24.78-25.08mm on 25mm test print
Posted
· Can't calibrate steps per mm... 24.78-25.08mm on 25mm test print
You should not change the steps per mm on X or Y or Z axis as they are dependent on the hardware which shouldn't change from UM to UM. The variation you are seeing is from things like shrinkage, overextrusion, and play (aka backlash).
You should print the part you want to print, and then figure out all the dimensions that need correcting - ones that must absolutely be corrected - and fix only those dimensions in the CAD.
I don't think you can get more accurate than .1mm so if you are getting .06mm accuracy then that is probably better than anything I've heard of being possible.
gr5 2,210
