kmanstudios 1,120
Depending on your needs, you can also use the adaptive layers found in 'Experimental'.
Or if you need fine control, Slic3r offers manual control of layer height.
Thanks to all that replied.
Specifically, I have an .stl file that's got a solid base, then one mm up is a logo and text which I want in a finer resolution which I will change filament. I want the text and logo to appear with a better resolution as the base does not need to be.
ahoeben 1,968
You would have to manually splice together multiple gcode files. What do you want to achieve?
