Changing resolution mid print
DDDmaker
Posted · Changing resolution mid print
Is there a tutorial on how to change resolution from .2 to another height, say mid print, to a finer .10 resolution?  Here on this forum and/or on YouTube.
Much appreciated for those who do answer.
    Thanks to all that replied.
    Specifically, I have an .stl file that's got a solid base, then one mm up is a logo and text which I want in a finer resolution which I will change filament.  I want the text and logo to appear with a better resolution as the base does not need to be.
