Layers Shifting/Don't Move
mattcwill
Posted · Layers Shifting/Don't Move
I first noticed my layers were shifting too much in the y-axis, as seen here when trying to print the Bezier Heary Bracelet from Thingiverse (http://www.thingiverse.com/thing:8521), which can be seen here & here:
Y-axis shift view 2
Y-axis shift view 1
At first, I thought my right y-axis belt was loose, so I tightened it, but to no avail. Having then noticed my top left screw on my y-axis motor was not completely screwed in, I ended up having to dismount the whole motor before realigning each spacer and screwing the motor back in, making sure to tighten the timing belt. I decided to also take that time to tighten my x-axis timing belt, just in case.
That seemed to make it worse as I now started to see problems in both the x and y direction with my extrusion head stuttering and not moving smoothly. Thinking it was a long pulley issue, I tried loosening and sliding my right y-axis long belt (didn't help), and fiddling with the left y-axis long belt (also didn't help).
For a side by side comparison of what's now occuring, Chopsticks for Kids (http://www.thingiverse.com/thing:38421), used to print as this when I first encountered the issue:
Chopsticks for Kids Problem 1
Chopsticks for Kids Problem 2
before now printing as this:
Chopsticks for Kids Problem 3
My extruder is square, so I know that's not the problem. Thoughts?
    Make sure that your short belts aren't rubbing on the frame, and are sitting straight in their pulleys. Assuming they are, then it looks like you have loose pulleys. Use a permanent marker to mark the position of each pulley on its shaft, and see which ones are moving as you print.
    I moved my short belts off the frame and tightened everything, and it seems to have solved the problem! I'm currently reprinting those chopsticks at 300 microns. My UM is running a bit higher pitched than normal, but I'm going to assume that's because of the decreased layer resolution (it's my first low-res print).
    Thanks for the help!
    I'm glad you fixed it. This is a common problem. You really have to tighten the hell out of those little tiny set screws. You should have gotten spares in your UM kit. I have heard that the spares are much better quality and if you get slips in the future throw away the old set screws and put in the newer pointier ones.
