fbrc8-erin 296
Are your heater and temp sensor both firmly inserted in the brass block?
Is the brass block touching the fan shroud? Has any filament gotten between the brass block and fan shroud?
Are you using an infrared temperature gun or something with a contact probe? Contact is usually more accurate for nozzles because of the reflectivity.
How does it feel if you push filament through by hand with it heated to 250? Is there any sign that heat is reaching the filament?
