Yes of course, what do you need exactly? And where do I find the log? (I am on Mac)
Thanks, I will repeat the steps in Cura, save profile, load a default one, change to the custom one, that you hopefully, see something in the log.
Hope I can do it tomorrow and come back to you.
Thanks!
@nallath Please find attached my zipped Cura log.
Today 15.8. I tried again a custom profile with some settings, Speed, Line Width, but they are not saved or they are saved but not restored after selecting the custom profile.
I don't see anything weird in the logs at first glance. Could you also share a project file of your setup?
I just installed Cura on another computer and here it seems to work after a short test. So maybe there is something wrong with my installation. I will try to remove everything and reinstall it, maybe it helps.
The steps I try to test is easy:
- Open Cura
- Select a default profile (Normal)
- Change the value for "Initial Layer Horizontal Expansion" to -0.25
- Save with "Create profile from current settings"
- Select again a default profile - the setting should now 0 again -> OK
- Select the previous saved custom profile - setting should now again -0.25, but it isn't
But let me check the reinstallation, maybe there is something wrong.
Update:
At home on my Macbook it was still the same, also after deleting all Cura related directories and reinstall. But after playing around with the profiles, I got an error message from Cura that something is wrong with the profiles and that I should reset to factory defaults. I did it and retested the custom profiles and now it seems to work.
So whatever happened and why the reinstall was not successfully, now it is working! I assume that I have missed maybe some parts of the previous installation and the "reset" fixed it.
nallath 1,080
Could you share logs? This seems to be a bug, as it should save values that you entered as a user.
