Hi gr5
I tried your suggestion and the lines are still there but are almost invisible, so that's good, but it has created all these start or stop points that are much worse than before. Do you know what makes them or better still, how to reduce them?
The first picture is with combing mode set to all, the second is with not in skin.
Thanks
gr5 2,330
try changing combing mode to "not in skin" and see if you like the results better. By default it doesn't retract on internal top layer moves and so you get these melted lines.
