I suspect the usb cable that communicates between the two computers. I'm thinking that the arduino is getting errors and asking the linux box to resend the gcodes thousands of times until finally a proper gcode gets through. You should dump the logs and post them to your reseller but I suspect you will have to return this printer to have it repaired.
There's a menu option on the S5 to dump the logs to a flash drive. Then you can look at the logs or just email them to your reseller.
gr5 2,243
