Many thanks gr5 for your feedback. I have not updated the firmare of my UMO recently. Also I had not seen that issue in the past.
I have made some slicing tests with Cura 3.4.1. and compared with 3.3.1 when slicing for UMO (incl. heatbed) and for UM2+. Very interesting results which may show an issue in the slicer in Cura 3.4.1. Below you'll see the calculated slicing times which are odd for the UMO in v. 3.4.1 as they differ by almost 80-100% for an UMO vs. the time for an UMO2+:
Example STL 1:
Cura 3.4.1: on UMO: 3:18h on UM2+: 1:41h
Cura 3.3.1: on UMO: 1:59h on UM2+: 2:08h
Example STL 2:
Cura 3.4.1: on UMO: 5:08h on UM2+: 3:02h
Cura 3.3.1: on UMO: 2:58h on UM2+: 2:14h
gr5 2,070
Well steps/mm is probably set wrong. Did you update the firmware on the UMO recently? Some versions of Marlin have a "motions settings" menu somewhere in there and you can view and set steps/mm. Fix that value by moving the bed 100mm and measuring how far it actually moves and dividing the difference and correcting the steps/mm of the Z axis by that value.
If you did update the firmware maybe you have UMO firmware on a UMO+? They have different Z steps/mm I think. Often you have to do "factory reset" to load all the defaults of the new firmware properly (loading new firmware sometimes messes up all the eeprom saved settings).
You have the white circuit board, right? There is a jumper near the center of the board that can affect steps/mm by 2X. If that is loose and jiggling that could cause it to occasionally step 2x but this seems very unlikely.
