1 hour ago, nallath said:Did you also set it to use the same acceleration & jerk? The speed is actually setting the max speed, which is quite different from actual speed (which is the result of max speed, acceleration and jerk)
Nope. I wouldn't know what to set it to. S3D does not expose any acceleration or jerk modifications that it may put into the gcode. I assume that it is using the firmware defaults. I do not set those values at all in my CURA profiles.
nallath 1,124
