cloakfiend 996
Yeah i use a dremel 4000 not even on the lowest setting but don't press down, let it rumble on the top and you'll be ok, the smaller the tip the quicker it melts. Thats why if you use a big 'burr'?, it wont melt. The needle thin small ones melted immediately. dont sit in the same spot as well.
I went a bit heavy on the super glue as filler and poor modelling meant that this model is bumpy because I didn't model it with hard edges and rushed it because I couldn't be bothered to hard edge it so the faces aren't actually flat. Ill fix it up a bit but seeing as its a destroyed Unicron ill leave the damage to the face.
My copper solution is contaminated and cant plate again till i replenish it and find some new reliable source to buy it from. ebay is sketchy and the folks who sold it to me admitted they were miss-sold the copper from the factory, whether thats true or not is irrelevant to me its ruined my setup completely. I said I would give negative reviews to them. we'll see, it was only £18 but i've already bought new copper for £12. Best to get it direct from factories as offcuts rather than resellers not knowing what they are selling.
Some pics before final plate. dont know why they come up as portrait?
Edited by cloakfiend
Smithy 1,145
Which tool are you using for post processing, Dremel, Proxxon? I think it must be something with slow speed.
I tried my old Dremel, it's working but it is too fast on the slowest setting and therefore melting the plastic nearly immediately.
