3d print fail - please help
Exitenz
Posted · 3d print fail - please help
I am a beginner at 3D printing and am having a horrible time trying to do my print.
I am using the following:
Monorprice select mini
3D solutech PLA
When I start printing, the adhesion is absolute crap. The filament doesn't lay flat even though I preheat the bed. The extruder catches on the filament and pulls it creates a huge mess (see photo). The print itself, is also crap. Its stringy and loose.
Can anybody help me with proper settings or tell me what it is that I am doing wrong.
Please and thank you
    If it's not sticking on the first layer it's usually because you aren't squishing the bottom layer enough.  But clearly you are.  So something is seriously wrong with your print bed.  I think it has oil on it maybe.  Try cleaning it with soap and water.  Or some other solvent like isopropyl alcohol (aka rubbing alcohol).  But I don't what the surface is.  Is that build tak?  Anyway try to clean any oil or wax or grease off the bed using soap and water or similar.
    The first photo -- if that's the underside of the part then that *might* be normal.  It's hard to bridge.  If that's a top layer - if it was printed with the visible bottom of the "box" facing up (orientation shown in your photo) - then you have severe underextrusion.  If so then the first thing to try is to raise the temperature to 240C and lower the print speed by 2X and then if that helps then experiment with other speeds and temperatures.  You should be able to adjust both of these while the printer is printing so you can do several tests on one print and save time.
    Thanks for the advice. That was the underside of the model. Is it possible to successfully "bridge" so I don't have this look and feel? The underside layers feel much more loose and less crisp that the rest. Thanks
