Everything is fine but it doesn't work.
fbrc8-erin 296
If it's not working, then something is wrong. Like @Smithy said, it looks like your printer stopped extruding. If it stopped extruding, because it couldn't exit the nozzle (burnt material, etc), then it would grind at the feeder because the feeder is pushing but there's nowhere for the filament to go.
Can you please elaborate a little more? When you removed the filament from the feeder, what did it look like? Do you have a picture?
Does the filament that's in the bowden tube have teeth marks on it?
If you load fresh filament, does anything extrude?
1
How to check about filament feeder if it is working or not?
fbrc8-erin 296
Remove the filament from the printer and look and see if a bite's been taken out of it.
Smithy 1,145
It looks like that no filament is extruded, because when printing in the air you would have a lot of loose filament in the printer.
Check if filament feeder is working, maybe grinded filament or clogged nozzle, or ......
