kmanstudios 1,074
There are so many factors that can affect the humidity that can get into PVA. I too use matterhackers PVA primarily due to cost. I can get a full Kg of the stuff for the cost of a .75 Kg of Ultimaker PVA. But, I do not discount using UM PVA though. There are times I want that stiffness. But, when you print with PVA, do you hear it pop and crackle? If so, humidity got in there.
Usually, I would try to tighten the tension on the feeder rather than back off. But, if you are grinding, you should take the feeder off and make sure there is no crazy stuff staying inside. The little bits and junk of ground up material. It will get stuck in the feeder wheel and make things just get slippery in there. And, make sure you are doing hot and cold pulls since it is probably building up carbon deposits.
Jakeddesign 14
When I run PVA on our UM3, I clean the nozzle every day or two, depending on how many prints I am running. To clean the nozzle I use the clear nozzle cleaning sticks sold by Ultimaker, which work really well. I set the core temperature to 220, push the plastic rod into the nozzle until the filament turns clear (indicated the cleaner material is moving through) then set the core temperature to 140. once it hits 140 (i call this a coldish pull) , I pull the rod out, usually bringing burned PVA with it. After a good cleaning, you should be able to see daylight through the nozzle when looking down.
Also, I tend to use Matterhackers PVA for a few reasons: #1 is that UM PVA is always sold out, #2 is that it is less brittle, so when the nozzle inevitably hits a support, it doesnt snap like the UM brand does.
Last thing is that if I am done with the PVA for the day, I put it into my air tight super dry box full of desiccant.
