3 hours ago, nallath said:You need to set the setting "support_extruder_nr" to 1 (instead of 0, which is the default)
If I recall correctly, this can be done by adding;-s support_extruder_nr="1"
Thanks!
I have tried 3 ways:
(1) Not modify anything of the fdmprinter.def.json, just add the command '-s support_extruder_nr="1" '
It is not help.
(2) Just modify the dmprinter.def.json, as this:
It is not help. Just like this:
(3) If I modify the default value of "support_infill_extruder_nr", like this:
It worked! But, there is an additional cylinder!As this:
Here is my json file.
Thanks!!!
nallath 1,124
