Command line execute CuraEngine, How to Generate T0&T1 ?
TK_HPU
Posted · Command line execute CuraEngine, How to Generate T0&T1 ?
I execute CuraEngine.exe by command line. The version is 3.3, I use ultimaker3.def.json and  ultimaker3_extruder_left.def.json and ultimaker3_extruder_right.def.json.
Now it is only one extruder, even though it have generate support.
How to modify the .json file, so that it can use both extruder1 and extruder2.
I mean, I want extruder1 be used for the model, the extruder2 be used for support.
Is there any demo?
Thanks!
    You need to set the setting "support_extruder_nr" to 1 (instead of 0, which is the default)
    If I recall correctly, this can be done by adding;
    -s support_extruder_nr="1"
    Thanks!
    I have tried 3 ways:
    (1) Not modify anything of the fdmprinter.def.json, just add the command  '-s support_extruder_nr="1" '
    It is not help.
    (2) Just modify the dmprinter.def.json, as this:
    It is not help. Just like this:
    (3) If I modify the default value of "support_infill_extruder_nr", like this:
    It worked! But, there is an additional cylinder!As this:
    Here is my json file.
    Thanks!!!
    json_file.zip
