I am having the same problem with Ubuntu 18 and Firefox ... when I click on Extensions-Manage Backups I get a window where I can click on 'sign in' and nothing happens. I got too much time invested in custom profiles to try and bring those over manually so Cura 3.5 is not happening at the moment ?
4 hours ago, jens3 said:I got too much time invested in custom profiles to try and bring those over manually so Cura 3.5 is not happening at the moment
You can run them side-by-side. If 3.5 is not working out for you, you can switch back to 3.4. Cura 3.5 does not change your Cura 3.4 configuration, it just makes a copy of it (and upgrades that copy).
Thanks. Yes, that is what I am doing. I did not 'upgrade' though but simply install the new version in addition to the old version.
nallath 1,113
I've forwarded this to the engineer that built it. He is on a holiday, so he might take a bit longer to respond.
