Judging from the very mixed experiences that turned up on a quick web search on this issue with pure PLA (ranging from "will crumble in no time" to "absolutely no problem") it seems to depend very much on the exact composition of the PLA filament.
If you can't test and want to stay on the safe side, CPE or a similar material (XT, NGEN, generic PETG) would be the way to go IMHO - at least if it is pure salt water, with chlorinated (swimming pool) water it can be a different story, judging from the chemical resistance charts I found for PETG.
Smithy 1,136
I have no experience, but I think it also depends if the part is only used for 24hrs and after that you throw it away or if you will use it afterwards also. 24hrs in seawater should be no problem I think - but I only guess!
