CuraEngine doesn't have default values (or well; it gets them from the fdmprinter.def.json). So in order for this to work, it needs to know where to find the file.
Hi, I want to create a database that contains the length, depth, width and the build estimation time of many stl. files (around 5000). Cura shows all these information after slicing.
Now I dont want to import each file and slice it manually. I want instead to automate the slicing process(possibly with a command line). If you have done this before @sneakersandgenes can u maybe help me with that.
nallath 1,124
reas 0
