Posted (edited) · Weird points on the calibration cube vertices
It is perfect in X-Ray view.
It is how it looks printed, just like in the slicer.
I found out using 0 as external wall insert lowers this effect hugely, but it is still there a bit.
Using a negative value helps but it is very weird and it can be flat with the rest of the surface, but then why isn't it flat already with a 0 value?
For last, why are the corners deformed?
Edited by redslifer
