Well,
it's the plate at the backside of the heater. How it's to see at the photo.
I could ask the reseller, that's a good idea. I'm sadly a bit worry, because on his shop site, I found no pare parts for my UMO+.
You wrote the hot end pack, well I think it would be the best what I could order, to get the whole parts on which I do not taken apart.
As described above, the heater and the sensor are how glued in to the heater block. So a new hot end pack should be the best solution. That I agree.
To that extent, thank you for the hint. I will test it by asking the reseller per E-mail in the next hours.
Best Regards, Arne.
fbrc8-erin 299
I have those parts available in the US, but, as it looks like you're located in Europe, I would definitely recommend reaching out to your reseller, as it will be a shorter shipping distance/less shipping cost to order locally.
It sounds like you need a UMO?UMO+ hot end pack, UMO+ temp sensor, and UMO+ heater for sure.
Which plate is broken? The large square aluminum plate in the printhead?
