Posted · cure 3.5 infill?
I think that is normal, because with the 1mm nozzle the line thickness is 200% of the 0.5 mm nozzle. Therefore also less infill, because the wall is thicker. Infill is, as far as I know, calculated how much material is used for infill, so if the line is thicker, you see visible less infill patterns.
