So you might want to tighten all 3 leveling knobs an equal amount - say about 4 full turns and then do manual leveling again. Or even better - loosen until the springs are loose then tighten about half way so the springs are all half way compressed. Then start the leveling procedure. I've only had to do this when I've taken the bed apart so this should be a pretty rare activity.
What you describe about plastic not sticking on the first layer sounds like a leveling issue where the bed is too far from the nozzle. You can usually verify by pushing up on the bed and if it gets much better then it was too far from the nozzle.
gr5 2,243
