It is now called Marketplace. It will probably have another name in a version or two...
Oh sure, keep changing it so we can't find it when following tutorials. 😛
Looked in Marketplace but still can't find the installed Pause at Z plugin (yes, I restarted after installing).
Pause at Z is not a plugin, but a postprocessing script. Pause at Z can be found in Extensions -> Post Processing -> change G-code (Add Script button)
Carla_Birch 116
boundarycondition 2
Got it, thank you! I think this setting should have remained in the Material menu, dimensional tolerance is a real thing.
ahoeben 1,956
Note that the Printer Settings category is only available if you install the "Printer Settings" plugin from the toolbox. Also note that the "Toolbox" has replaced the plugins menu.
n0ukf 0
In 3.6 I installed a Pause at Z plugin but I can find neither Plugins nor Toolbox to use it.
