ok, thank you very much ?
Welcome to the forums!
The IP and MAC address are indeed found in the menu. There is a small hoop to jump through when you don't have a connection yet and want to see the MAC address. I've outlined how to get that here.
There is indeed no driver necessary. If your IT department needs ports: 80 (API, Webcam, Cura, Cura Connect), 5353 (Zero-conf/mDNS).
Hope this helps you out. If you've got more questions, please let us know.
1
Thank you. I forwarded your post to our IT department.
Dim3nsioneer 557
There is no network driver for any Ultimaker printer (so far). However, your IT department has to make sure that necessary ports are open in order to allow communication between Cura and printer. For information about those ports and protocols please contact your Ultimaker reseller.
edit: almost forgot: welcome to the Ultimaker community ?
Edited by Dim3nsioneerLink to post
