Yeah it's weird. It should be level at the back since there is no way to tilt it there.
Maybe I should try taking it apart and add a spacer in the back mount or something. Was hoping this is a common issue, but since I couldn't find it as such, I already worried that it wasn't.
yellowshark 153
Well I cannot consider myself an expert on this particular point as I have never had the problem. But I have always considered that the level on the X axis is controlled by the two front screws - for the entire bed - and that that rear screw sets the level on the Y axis. Of course if you have a warped bed then I suspect you are stuffed with a 3 point levelling design.
