Hey, thanks! I most certainly can... I mean, I most certainly want to. What should I upload that would be the most helpful?
Really it isn't about saving what I have (I know my bed dimensions and such), but it would be nice to put one in that will have some future-proofing.
There's no nozzle offset, really nothing special at all, it's just a CR10s with lower accelerations (heavier head) and a second extruder. I was hoping I might take a built in profile and just make a couple changes and hit "save as".
(Aside: I don't think I remember the #2's being in the window. But unsure.)
Attaching a .3mf export, not sure if it has settings.
Edited by AbeFMAttaching 3.5.1 3mf
nallath 1,104
There is probably a bug that gets triggered with your setup that we didn't find about yet. Since this has been going on for some time with you, I expect it's the same bug.
Could you share the logs and the files you created? I can't promise that we will be able to fix it anytime soon (as there is always more work than time), but I can probably at least tell you what's wrong (and hopefully provide at least a workaround)
