Yes often a tricky one; you have an inherent problem caused by the required change in pressure which does not happen instantaneously, it takes time to settle down. That is why 99% of the time I print with all speeds set to the same value.
With regards to your last comment, I have often wondered why Cura does not allow you to specify the speed change to happen during the last part of the infill.
I am only on 2.7 and so not aware if there have been subsequent changes that would help. All I can think of is to print the wall inner to outer and if need be add an extra wall. I normally go outer to inner because that is meant to improve dimensional accuracy which is normally important for me.
Also if you are printing something, maybe a bust, where there is a definite rear which will not be seen, then use the “user specified” option of the Z Seam Alignment to start the layer on the rear section.
yellowshark 153
